Motorola Microphone question?
mmayhorn2002
Madison, WV
Someone please help me in my quest. I have two Motorola CDM 1550's one vhf and one uhf in my vehicle. I was wanting to know if anyone knows of a product made to connect one microphone to both radios and be able to switch them back and forth when needed. Thanks in advance.
davidgcet
nothing factory, though it could be done with a multi pole switch or a big rotary switch and some engineering.
mmayhorn2002
Madison, WV
Thanks for the response. That is about what I was thinking, I just hoped someone made such a thing before I had to sit down and figure this out myself!!!
jackj
NW Ohio
Talk to your local Motorola Service Shop, they could probably design and build one for you.
W2NJS
Washington DC
Price? The cheap one is between ten and twenty bucks. The expensive one, which you don't need, is probably overkill by several hundred percent. Everyone I know who switches RJ45 mic lines uses the cheap box because it works fine.
adamr368
NJ
California Highway Patrol had a custom mike developed with a rocker style PTT switch would allow the selection of different options. If you can find one on ebay and are good with electronics, this would be the mic for you... I posted a link below - you may have to scroll down to see it.
CHP RADIO SYSTEMS
