Motorola Mototrbo CPS
LowderK
LEO / Paramedic
Western Oklahoma
Does anyone know the latest version of Trbo CPS..? also what is the latest Firmware version for the XPR3500e...?
PACNWDude
Latest Trbo CPS 2.0 as of 21 July 2021 is version 2.110.120.0. Firmware, you will have to get into Motorola Solutions online and check for that, do not have any XPR3500e's myself. I do not commonly upgrade firmware unless there is a very specific need to do so. Learned that lesson years ago.
LoveMoto
So I just got a new SL3500e and my CPS 2.0 is saying "code plug version not supported". I am just using a basic usb to micro usb cable so either my CPS is too old or I need a special programming cable. My CPS version is 2.18.95.0. Before I get raked for trying a simple cable that is how SL7550's that I have can be programmed. Anyone know the solution to my situation?
K2NEC
NA
Your cable should be fine as long as the radio is recognized by your computer. So I'm gonna venture out on a limb and say that it's a firmware ver/software ver mismatch.
LoveMoto
In CPS 2.0 is there any way to copy the code plugs for different model radios or do you have to build each one new. Am afraid I know the answer.
K2NEC
NA
You can open a non 2.0 codeplug in 2.0 and it will convert.
LoveMoto
Aha. Open two CPS side by side and copy-paste
Once you convert the codeplug from 16/828 into CPS 2.0 will the old 16/828 code plug still exist? Scared of Motorola
Duh I could just rename it and save that one in case.
Thanks for your help tonight!
wb1ccp
Lebanon, CT
The current CPS 2.0 version as of October, 2021 is 2.110.235.0 .
To open older code plugs in 2.0, you need to have CPS 16/828 installed alongside it. Even with that, some very old code plugs will not open in 2.0 no matter what. (Growl!)
I don't recommend programming Generation I radios (XPR4000 / 6000 / 8000) with CPS2.0. I have seen them misbehave badly after that, particularly Connect Plus radios.
OhSixTJ
so what do you recommend they be programmed with.
wb1ccp
Lebanon, CT
CPS version 16 build 828, the last release of the earlier CPS. If you need wide band (Ham, GMRS, marine or T-band) and you don't have the EID for wide band, version 8.0 is the last one that will allow wide band. That one might not work with later firmware, though.
n3obl
Ø
PA
There an easy hex edit found with google search to enable wideband in CPS 16
n3obl
Ø
PA
I’ve just started looking into these radios so excuse my ignorance but what does “wideband” give you on them?
Compatibility with channels that still require wideband. Analog Ham, Marine, railroad and some other services are still wideband modulation vs narrowband.
LukeB
Trying to read a radio with CPS 16.0 Build 828 and getting Error 1027 Codeplug version not supported. I have the wideband patch for CPS 16. I have version 2.0 and want to install it but i dont want to lose the spacing patch. Is this the workaround being discussed above or can i just copy the .dll file and paste it into the 2.0 version folder?
K2NEC
NA
If you already have the 16 version and you install CPS2.0, it should carry over into the 2.0 CPS.
Edit: Correction, if you have a legit key in the 16 software, it will carry over into 2.0
