Motorola Programming Error number 81
FireMan16
Riverside County
i got a hi power vhf spectra and i go to read it and it says,Error number 81 has occurred cannot access the Ext Security Housing Consult manual for list of error codes
and possible solutions,i dont have a manual to look at,can anyone help
mancow
N.E. Kansas
Do you have the ASN box with the system?
Spectras occasionally show up on the market with the ASN box removed. If that's the case you will never be able to talk to the radio unless you put an ASN in the system. The RSS is looking to talk to that box and will go no farther without it.
The only way to correct the situation is to put a working ASN on it then go in the RSS and switch it from external security housing to either internal or no encryption.
