Motorola Quick Call Codes.
Newjersey
Can anyone convert a Motorola quick code that was on a Centracom II console to the frequencies and duration of the two tones. The quick call code is 3977
Thank you very much.
N1GTL
CT
7 = 1006.9 but you wouldn't have back to back codes the same.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Quick Call II tone timing is standardized. First tone is 1 second, the second tone is 3 seconds. There's no time lag between tones.
Better explained in great detail here: Two-tone Paging
There are also several other sources on the net for detail info on tone paging including QC-II.
There's no guarantee that the code number assigned to the pair will match a Motorola tone plan. Too many other tone schemes have been incorporated into Centracom II and other console systems for that these days. One of the agencies here uses tones from a Plectron chart, but they're programmed into a Motorola console system and use standard QC-II timing. The internal code number assigned in the console system really can't be decoded with a Motorola chart unlike the old days. We've also got agencies using tones from an old Motorla QC-I chart, but again, with QC-II timing. Tradition is a wonderful thing.
Better to use something like RadioID on your smart phone to identify the tones. Then you will be certain that you've got the right tones.
kf8yk
CCII pager code 3977 converts to 1006.9 Hz / 2361.0 Hz, standard 1 second / 3 second timing.
Newjersey
Wanted to thank all for their replies. Will let you know how it works out.
