Motorola Saber 2
altereffect
Minnesota
Do I need to set a squelch on my radio? Some of my electronics interfere with the radio. I f I need to how do I request the squelch to be programmed? For receiving my local police department do I need to enter the PL codes for each frequency? Can the police style PTT ID be programmed in the Saber 2?
Also can anyone list all of the programming options for this radio?
thank you
W2NJS
Washington DC
If you are set up to program a Saber 2 then all of the options are listed in the program. The squelch is set for each channel in the software. Yes, if you need PL you must enter it for each frequency and for both the receive and transmit channels if you're transmitting on that channel, otherwise you just program the radio for receive and program the transmit channel as "blank." The PTT ID can be programmed into the radio; it's called MDC and, again, the program will make it clear as to how you set it up. However, if you're the only person on your repeater, for instance, who uses the MDC ID your associates will not vote you "most popular" because the sound of the ID is a real annoyance to anyone who is listening to you. The Sabers are great radios that are pretty bulletproof both as to physical toughness and electronic reliability. You can see some additional information about them at Batwing Laboratories under Model Specific Information.
