N6DRA said:
H44TUN5170CN is a 403-430 MHz "Secure Capable) System Saber. It will likely have a dummy plug for the encryption module. I bought one and changed the modules to the higher split. Basic Saber's are dirt cheap in all flavors and the modules all interchange.
Tim
That's incorrect..
The model number will ONLY tell you that it's VHF or UHF, it will NOT tell you the bandsplit......
RF components are swappable between the systems saber and regular saber, HOWEVER, they're only swappable in band, you can swap any UHF component on a UHF board, and a VHF component on a VHF board, you can NOT take a UHF saber and make it VHF by putting VHF RF components on it, the board is different.
SO, 403-430 saber into 450-470, absolutely
403-430 saber into 146-162 , NO!
