Motorola Systems 9000 & Syntor 9000
DatedGore
Indiana
You'll need a 2135 key for the radio drawer head so you can remove it from the mounting baseplate...when you get the radio, of course.
Be sure the radio include the mounting plate.
Thank you very much for all the information and help, I do have a Syntor X900 already, it's VHF if I recall. I plan to get it all set it up at some point. The only thing now it would seem is the programming. Ill have to look further into that
ElroyJetson
I never had any trouble with that clip but I was careful. Just treat it like anything else that has teeth.
Thanks to this thread I remember who got my X9000. I should contact him and ask if he still has it.
DatedGore
Indiana
Last time I bled doing ham radio stuff I was stripping wire not paying attention and caught my finger on the wire cutter part, I started bleeding but at least I was working with red wire lol
RFI-EMI-GUY
There's supposed to be a metal clip on the head end but they are always missing.
I almost bought a radio just for the clip. They are sort of pricey. They are required because the rubber part of the plug that serves the same purpose breaks off.
radioman2001
New York North Carolina and all points in between
For the siren or the extender you need a special cable that goes between the radio and the control head cable. I have seen stack packs of up to 4 of these cables for the X9000. BTW don't try and hook up a X9000 to standard SyntorX or vice versa they are completely different and will let the magic smoke out if you do.
These 2 products shown are for the X9000 only.
BTW for 6/10 meters in one box they are really good, mine put out about 130 watts.
DatedGore
Indiana
I had found the original wires that came with the unit, so now I do have the functioning radio and siren amp. Works like a charm :)
RFI-EMI-GUY
A tip if one wants to have a 10M and 6M antenna on the vehicle and not use Motorola's diplexing cable scheme. Buy a Comet CF-360 diplexer. It has a 1.3 - 30 MHz port and a 49-470 MHz port. Good for 600W PEP. I also intend to augment mine with a remote coaxial relay so I can bypass the ham antennas with an NMO at 43 MHz.
As far as the term "Extender". What Radioman means is a vehicular repeater system (VRS). GE used the term "Extender" for that operation.
The Low Band Motorola radios have an "Extender circuit" (and optional on/off button) which is a noise blanker.
I intend to add an aftermarket VRS , a Pyramid SVR200U, and will splice in the connections at the normal control cable plug as the OEM "stacking" arrangement is quite ridiculous and can damage the radio personality board connector.
