I was under the impression the 7550 came with the option board. It was optional in the 6550.
The E series comes with the battery the selling dealer orders. In my case, my dealer had inventory of E radios with the slim 2100 ma battery.
MCore25 said:All 2nd gen radios are capable of capacity max. Not just the gen 2.5 (e models).
I honestly do not know which E version I have. All I know is in the first page of the CPS, which lists the options in the radio, everything is "purchased". I don't use Bluetooth by the way, I just wanted to upgrade for free, & get 3 more years of warranty.
Should they pull down the four YT videos where they're doing exactly that ?
Although I think there was an app that let you configure your radio via BT using your phone.
THAT I could totally be wrong about.
I think it only has a Cap + board doesn't it?
Capacity Plus doesn't require an Option Board.
The Option Board is generic, comes pre-installed on second gen radios and can be flashed with anything.
My radios all have Connect Plus trunking firmware on the Option Boards which I loaded using Connect Plus CPS.
Is Bluetooth a option or built into every xpr7550?
Like if I bought a used one on eBay Bluetooth is a standard factory option or something to be purchased? Also the connect trunk option does that mean the radio is stuck in trunk mode? I just need to know what to radio to purchase that isnt going to require additional purchases....
So are there hardware differences between the capable, & enabled, or just features when delivered, because my capable has been "upgraded" with every feature possible.Here are the model numbers.
Capable:
AAH56JDN9WA1AN - VHF
AAH56RDN9WA1AN - UHF
Enabled:
AAH56JDN9RA1AN - VHF
AAH56RDN9RA1AN - UHF
The Capable models come with the IMPRES 2100T.
The Enabled models come with the IMPRES 3000T.
Ah so if I dont have a programming cable I can use Bluetooth to program the radio. That is awesome because I have several Panasonic CF30, and CF31s with full features, Bluetooth, finger print scanner, gps, 4g that I have built from the ground up. Now I dont need to dred on buying a $100 programming cable. As for the E model I see no reason to spend $700 on that model when I am seeing the non E models om eBay for $500 or less.There are no hardware differences. It's all entitlement keys that control those features.
The general premise behind the Capable model is that instead of paying the additional price for the Enabled model, you can simply get the Capable and then purchase only the additional features that you need, thus saving money.
And honestly, sometimes it's just better buying the barebones Capable model, because you can spend the additional cash on extra batteries or accessories or what have you. The only reason you really need WiFi is if you don't have a bluetooth enabled computer. Sure, you can use the programming cable (and have to for firmware updates), but it's SO convenient to do it over the air. Capacity Max? Most people aren't going to use that.
Ah man, ok thank you, I found a ham on eBay that makes cables for the radio and there only $20. Which isnt too badYou'll need to borrow or buy a cable to setup Bluetooth on the radio and you'll need a cable for firmware updates.
What if he doesn't want firmware updates?
