Motorola XTL Question
LCT123
I'm learning how to program an XTL VHF radio and I am having trouble understanding the frequency option tab under personality page. Can someone give an example what this would be used for. Is it used for Xmit or receive, Trunking or Conventional? Also does anyone know of a way to view the tutorials in the CPS. Can't find anything to take the place of the out dated Flash Player. Thanks
ElevatorsAndRadios
yarewesog
SoCal
It's used for Mixed Vote Scan, which is a type of conventional voting. Unless you are using your radio on a conventional multicast network that expects subscriber radios to vote, ignore it :)
LCT123
So if you have a station that has two or three fixed bases does that mean they are using simulcast and would you program the Fixed base two and three frequencies on the Options page?
GTR8000
NY/NJ Database Guy
BEE00
Conventional Vote Scan is used in pretty limited circumstances, and likely doesn't apply to you.
It would be used when there are multiple geographically separated base stations that are broadcasting the same voice transmissions on unique frequencies, and you want the radio to find the strongest signal. In other words, it's useful for multicast, not simulcast.
LCT123
Ok Thanks, I have one station in South GA that I want to program in that covers a very large area and they have three tower sites. I think I will program them in and just see what happens. My guess is that it is multicast.
LCT123
No they are different freq's and have different NAC codes, but they all go to the same dispatch which is GPS Waycross. Its a large area due to the Okefenokee swamp. Not sure on the SWF files, I will have to check on that. All I know is the video tutorials default to an outdated Flash player.
a417
Yes, but there are shockwave/flash players for standalone playing that does not play them in a browser window...that's why I'm asking.
wgbecks
NE Wisconsin
Here's a workaround solution.
Using your favorite search engine, locate and download flashplayer_32_sa.exe to your PC. Create a folder "Flash Player Support" or whatever title that you desire to name it and place it directly under the root drive (C:\) on your computer.
The tutorial files (.swf) are placed in C:\Program Files (x86)\Motorola\ASTRO 25 Products\ASTRO 25 Portable CPS\Tutorials when installing ASTRO 25 Portable CPS on a Windows PC that were originally called by html files from withing CPS when clicking on them in the
help section.
My solution for viewing any of the tutorials as will was to create shortcuts to each of the titles (.swf) and placed them in a separate folder
that can be under the root or even on your Desktop. Create a file association by file type for the .swf files that points to flashplayer_32.sa.exe that you downloaded and setup per the above instruction.
Now, it's only a matter of clicking on the title of the tutorial of interest and the associated .swf will open in the flashplayer debugger program
and you're off to the races. I believe that tutorials are identical be it ASTRO 25 Mobile, or ASTRO 25 Portable CPS meaning that you should
only need to create one set of shortcuts to view them in reference to working with ether CPS program.
I suppose a person could also hack the original html files too and accomplish the same end result. I just found it easier to create the
Windows Shortcuts and setup the file association to the debugger.
