Mototrbo accessory audio adjust
Like I have posted here before, we are now using XPR6550's with the accessory mike that has the switch on top to go from high audio to low. Seems like the high level is almost loud enough for the factory floor, but the low setting is still too much for in the offices.
Is there a setting in the software for the audio level for the low setting on the accessory mike?
gary123
there is nothing in the user menus that can be used to set the level. there might be soemthing in the service (tuner) that can be used.
Thanks Gary. I took a look thru the menus for a few minutes, but I had some other stuff needed to get done before the three day weekend. I didn't get the tuner cable for the portables, but I did for the mobiles. I really want to get into wireless SCADA with these radios. It's the main reason I decided to go MotoTrbo.
