Mototrbo CPS Export
N8VDS
Flint,MI
Is there a way to clone/export a Motorola XPR4550 codeplug to a XPR5550 with CPS Ver 16 ???
Thank You
alcahuete
Southern California
You can copy and paste from one window to another. It won't get everything, but it will get the zones and channels and such.
otobmark
NC
Been awhile but there is an order of doing things that make it easier. First copy and paste the contacts/TG stuff. Maybe receive groups too, again not sure if they will paste. Next input by hand (I don’t think you can copy and paste—) all of the scan groups making sure to name them identically to original. You don’t populate the lists, just name them. Then when you copy and paste zones and channels they will link to the TGs and scan lists automatically so you needn’t do them one at a time. Later you will have to populate the scan lists manually. Basically the pasted channels are looking for the TGs and scan lists they were originally programmed for in the donor radio plug. The idea is to have all the options referenced by the channel in place first and copy in channels after. There will be some cleanup to do but much less than if you paste channels early. I think if you grasp the concept you can reason your way through. I like that motrbo looks for names of thing rather than list position when accessing or linking. I have done this between portable and mobiles of same generation (07550 - 0550) but cannot vouch for mixing generations. Best wishes
