MotoTRBO Firmware Update
RESQ766
I purchased a MotoTRBO XPR 5550. It is currently running on firmware version R02.30.21 and CP version 06.03.10. I am trying to update the firmware to the most recent version I downloaded the firmware and installed it but when I try to update the radio with CPS 2.0 it tells me that the codeplug version is not supported. When I try with CPS 16 it tells me that no package could be found. How can I get this to work?
RESQ766
If you used the most resent FIRMWARE you have to use the most recent SOFTWARE which has been posted here.
I am using the most recent software but when I try to update the firmware it tells me that the codeplug is not supported.
celltech25
Benton
You may have to step it up in increments, I have had bad luck trying to jump big gaps in firmware updates..
also have your tried to read and write the radio in 2.0 before the update
RESQ766
For some reason I only see version 2.9 and up
RESQ766
Are you aware of the consequences from doing that? I wouldn’t do anything, unless there are specific features the newer FW will give you that you are dying to have.
I need to in order to use my mobile control head
Tech21
You need to update firmware in increments. 2.3->2.xx->2.xx.
Code plug version not supported is because the CPS version doesn't support that firmware or codeplug version. Update in 16.0 to 2.9 and then update to 2.10 in 2.0
IMPRES2
All of mine sit at R02.09. Last "safest" firmware.
The latest, “safest” firmware is R02.10.05.0002
I manage a Customer fleet of over 1200 XPR 5550 (with a decent mix of K/W/R indexes) with zero issues on that firmware; after you learn CPS 2.0 it isn’t much of an an issue. I will say that transitioning from 16.0 to 2.0 was a multi-week learning process.
To answer the OP’s question; if you are on R02.30.01 then you are running the very second release of TRBO firmware. You never want to jump more than two versions at a time unless you don’t mind the risk of your radio failing out and bricking.
I would recommend locating the below firmware packs and CPS versions:
FW: R02.50.04
CPS: R12.1 (Build 645)
FW: R02.07.01.0000
CPS: 14.0 (Build 717)
FW: R02.09.01.0001
CPS: 16.0 (Build 823)
FW: R02.10.05.0002
CPS: 2.21.61.0
K2NEC
That's the thing, CPS2.0 sucks. All it's features (or lack therof) and it's SUPER slow and unresponsive, make it a difficult piece of software to use and many consider it a step backwards from R16. I could argue about this all day but it's not related to the OP's question, and this isn't the time or place to do it.
Firebuff880
Boynton Beach, FL
I would never manage this many radios with CPS anything -- You need to get on the Radio Manager band wagon.. CPS 2.0 was an after thought when the community rebelled against an RM only solution. But it is far from complete and never will be, I would not even bet against it going away completely in the future.
As far as stable firmware, I agree, unless you have a specific Cap Max need I would stay on R02.10.05.nnn as well, An to go beyond that you will have to get there first !!
IMPRES2
It’s all RM now :) that was part of the upgrade and migration process but wasn’t relevant to this post so I kept my original reply short
