Mototrbo Frequencies
dryan83
Hey,
can anyone tell me what frequencies are used for mototrbo? Is there an exact frequency I can leave the scanner on so I can see if my decoder is working properly? i am using the Ian Wraith windows version so just want to know if data is coming in to see will it decode it with my sound card!
davidgcet
it uses the licensed frequency of the agency you are monitoring. can be VHF, UHF, 800 mhz or 900 mhz, all depends on who has that system and what they needed.
KE5TLF
MS Gulf Coast
Any frequency with emission designator 7K60FXE is a good start albeit certainly not all inclusive. Entities do change radios without chaning license info sometimes. Also some licenses have multiple modes on them some of which may not be or may never become active.
dryan83
OK thanks we will try 800 / 900 mhz frequencies!
what i am looking for is the frequencies of PMR, DMR mototrbo if anyone knows them!
mmtstc
Ø
Minneapolis Area
Your best bet generally will be UHF. There is a wiki article that is kept pretty current called MOTOTRBO that has a list of all MOTOTRBO licensed systems...
Sent from my Verizon Wireless Carrier Pigeon using Tapatalk Pro.
Forts
Ontario, Canada
I find searching small ranges at a time (such as 420-430, 430-440 etc etc) helps nail things down. Listen for the occasional 'braaaap' of digital that TRBO systems generally give off every 10 seconds or so.
jimvm
Olivehurst, California
Mototrbo repeater / on channel or are two freqs.
Is Mototrbo capable of on channel repeat? This means no duplexers needed, just one licensed frequency.
The radios and repeater are on same frequency, just time division seperated.
If not, why?
jim vm
JRayfield
Springfield, MO
Comint
Queensland, Australia
If not, why?
jim vm
No. And I would say because the Transmitter would desense the Receiver and the Receiver recovery time is a lot longer that the time slot.
Comint
Jersey Shore,NJ
Mototrbo?
I'm not sure if this is the right area to ask/post this but.
Has anybody in southern New Jersey shore area logged some sorta of "noise" on 152.030?
It's suppose to be one of Morey's Pier frequencies, but I'm not sure considering the strength of the signal in the AC area.
jcardani
Orlando, FL
I think you mean 153.020. It is part the new AtlantiCare Medcom MOTOTRBO wide area system. Morey's Pier is also licensed to that frequency.
The site location for the MOTOTRBO freq. is Ocean City.
JRayfield
Springfield, MO
The receiver recovery time is not longer than one time slot. Otherwise, transmit interrupt would not work. Technically, it is possible to run 'full duplex' using TDMA. That's how TDMA cell phones have worked for years. So, it should be possible to do an 'on frequency' repeater, too, repeating between the two time slots.
John Rayfield, Jr. CETma
Comint
