MotoTRBO Handheld Control Head Programming
RESQ766
When I plug my generic USB-A to USB-B cable into the handheld head the CPS says “[#1001687] Unable to detect applicable device(s). Check to see if a compatible programming cable is used.” I've tried 2 different generic USB-B cables and im still having the same issue.
Tech21
You need cable PN 300094770001 or PMKN4010.
Former is the control head programming cable, latter is the rear-accessory programming cable
