Mototrbo Programming
FransMiller
How can I program a "Busy Channel Lockout" feature in the DP3400 portable in Digital mode. I want to be able to use same simplex frequency on two different channels but if one channel is in use the other channel should not be able to transmit when pressing the PTT button and a tone should alarm the user.
knowmototrbo
Not sure if this helps, but if it's on the same frequency you should just need to verify the admit criteria and the in call criteria and make sure tones aren't disabled. In order for two radios on the same frequency to not try and talk over you would need ( as of ):
Admit Criteria : Channel Free
In Call Criteria : Follow Admit Criteria
To change these settings in CPS you would be viewing the channel, but you would need to ensure that Expert view is enabled (Menu > View > Expert).
This is for US firmware version 1.06, but for the most part I think this applies to most all up-to-date models.
Let me know if this helps.
