MPSCS Sites/Talkgroups 2021
freema22
Michigan
I have a silly, borderline stupid question. I have been listening to MPSCS for about 5 years on a Whistler WS1065. My reception has always been "meh" and I always chalked it up to poor location. However, I'm wondering if I programmed my scanner wrong. Do I need all of the frequencies listed for a site programed in (my current setup) or do I just need the control channel and alternate? Just curious.
Mike
hruskacha
Muskegon
Mike
Usually all you need is the control channel since it'll direct the radios to the talk frequencies. But if your radio has any database access, its a great way to sync it to Radio Refrence, or Uniden Sentinel.
stwings
Michigan
Are you monitoring a simulcast site or a single site? Simulcast sites are tricky and require a little tweaking to get them to play nice.
kb8q
Ferndale, MI
I have multiple Whistler TRX-1 radios as well as a GRE PSR-800 that was upgraded to a WS-1080 by Whistler. I have no issue with simulcast reception on P25. However, I use the radios mostly at home where I'm 2-1/4 miles from a site. The audio quality begins to vary if I'm mobile depending on distance from the nearest site.
James
krokus
Southeastern Michigan
Mike
If you are in a simulcast area, your radio will have issues with that. What happens if you scan a nearby county's site?
hockeyref2
Northern MI
4807 - MI NG Fire... alpena state RID's, grayling and alpena area, fire training grounds?
4580 called 40lein kalkaska law RID, no response
6163 - EMS helo trying to get to munson ER, no response
6157 - region 8 Medical? Marquette CO radio ID's
5510 - great lakes energy
5499 - great lakes energy
5498 - great lakes energy
5383 - lyon twp Fire/ems units... very little traffic
5335 "F500" Missaukee co RID's so perhaps 57f500. Norwich twp fire per wiki
5224 - '51 to rescue 5' missaukee RID's... norwich twp?
4526 - wexford co, station 600 (haring twp), tac?
4523 - wexford co, cherry grove twp fire tac?
4397 - wexford co page to station 500,300,700
4391 - wexford co fire paging slagle-harrietta twp station 'ten hundred'
1835 - MI NG 'FS1' aviation related
11844 - MI NG alpena RID's, security related.
iMONITOR
Silent Key
S.E. Michigan
A Whistler WS1065 will not work with Sentinel, only the newer models of Uniden's.
The Whistler will work with PCREdit-500, Butel's ARC500. I don't recommend Don Star's WIN500. Support is no longer available.
freema22
Michigan
I am using PSREdit500. I still don't know the answer to my question. Do I need all of the frequencies, or just the control channels? I am using the MPSCS site at Northville which I don't believe is a simulcast site.
iMONITOR
Silent Key
S.E. Michigan
All you need is the control frequency (RED). It's a good idea to include the alternate control frequencies (BLUE) as well. If there is a problem with the main control frequency the system will go to one of the alternates. It is not necessary to program all the voice frequencies.
freema22
Michigan
Great! Thanks!
freema22
Michigan
You're welcome.
Is the problem you're having distortion? It may be due to simulcast commonly used in Michigan. The WS1065 is not ideal to cope with that. What are you using for an antenna? How is your signal strength?
Just general lack of traffic. My location is literally in the middle of the Pontiac and Northville MPSCS sites. Can I program the control channels for both sites in an effort to grab whatever signal is stonger?
iMONITOR
Silent Key
S.E. Michigan
Yes you can program more than one site, but it will slow down scanning to some extent. Keep in mind different sites can handle different talk-groups, as well as redundant talk-groups but not all sites handle all talk-groups.
Maybe some RR members near your location(?) will chime in here with some suggestions.
kb8q
Ferndale, MI
There's more traffic on Northville. I would favor that one if I had a choice between the 2. Or get a second radio and monitor both.
krokus
There is not a lack of traffic on Northville, unless the site is down. I have not programmed the Pontiac site into anything, so I have no idea how much traffic is on that one.
Are you scanning a list of certain TG, or using a wildcard? Which TG are you interested in listening to?
nvanw27
WSDU482
Kingsley, MI
Norwich has been simulcasting on MPSCS and VHF as of recent. I can hear them on 154.400 most nights when they pager test. Mondays and Thursdays at around 17:30 they do their pager test, see how many units and departments go out on Missaukee Fire then. They might be switching over soon.
