MT-1000 Low Band Help
KG6GTH
Los Angeles County, California
Well Have a few questions / issues maybe someone can point me in the right direction:
Picked up an MT-1000 Low Band... Great lil radio!
Issue #1: I programmed the RX to Carrier Squelch, however I have to press the monitor button on the side of the radio to hear anything.
#2: Scan The little "Z" is usually scan on, when I go to the software to program the scan ho do I manually select the channels I want to scan? (If that makes sense?)
My big issue is #1
-Sean
ramal121
Lots and lots of watts
Calif Whine Country
1) In addition to setting the channel to CSQ, make sure there is no signaling system set for the channel.
2) A 16 ch MT1000s scan is programmed manually by the buttons. Move toggle switch out of scan. Press and hold the top side button (above PTT) then move toggle switch into scan. Radio will beep, release side button. Turn knob to channel you want to scan and press PTT, radio will beep (not tx).
Repeat for all your scan choices. Now move toggle switch out of scan then back into scan and you are good to go with a new list.
