mt1000
kb1oar
Banned
does the mt1000 have a scan feature and if do can you chose what to scan and not to scan without the computer. for example the gm300 you hold in scan and tell it what to scan and what not to. thanks
CCHLLM
MT1000s do have scan capabilities, and the scan configuration is done with the RSS. The scan list is limited to 8 channels and can either be a couple of variations of fixed list, or it can be user programmable. If the radio is programmed for user programmable scan, you can alter the scan list and number of channels scanned at will.
GTR8000
NY/NJ Database Guy
BEE00
The MT1000 can hold up to 8 channels in the scan list, but you can get it to scan 9 if the radio is programmed to Priority Scan and you don't include the priority/selected channel in the scan list.
To program manually:
- Press and hold the button under the squelch/monitor button
- Toggle the scan switch on top of the radio from one of the non-scan positions to the scan position Z
- When the radio beeps, release the button on the side of the radio
- Go to the first channel you want in the scan list and press the PTT button. It will beep to confirm
- Go to the next channels you want and repeat
- When complete, toggle the scan switch back and forth and the radio will beep to confirm the list was saved
