KC2zZe
Question 1:
On 160.9500 (Hudson Line), I hear references to what I believe is "Poughkeepsie S & S" around the Poughkeepsie station. What does S & S mean?
Question 2:
On 160.8000 (Port Jervis Line)... M-NRR was doing maintenance on the radio towers around me. They would call out to "ROC Rail Communications" as part of their radio check procedure. Who/what is ROC?
Question 3:
Also on 160.8000... after a train passes over a defect detector every roughly ten miles or so along the Main Line and the detector announces the results of its findings, I hear the engineer of the train that was just checked get on the radio and acknowledge the results found by the detector (thankfully almost always "No Defects" followed by "Detector Out."). The detectors are of relatively low power output, so only the passing train (and anyone nearby the right-of-way) can hear the results. Who is the engineer talking to when he acknowledges the detector's findings? Is the defect detector programmed to expect an answer back?
Question 2:
Question 3:
