When you program a MTR2000 for a wide channel, the only selection I see in the pull down is "20-30k". How does this work if you just want 25K? What is the actual bandwidth the MTR2000 uses for this selection?
My concern is that I want to program it to TX on wide band at 462.7250 (at 50W), but there is a business about 8 miles away that uses 462.7500 and I don't want to leak over and interfere with them. At 25k I will be fine, but what if the MTR2000 actuality uses 30K? I may still be fine, but I really don't want to interfere with them.
According to the FCC database they only have one freq (462.7500 @ 25W) and 25 pagers. I suspect it is just a paging system. I don't think I could interfere with that anyway, but....
I am used to various other vendor's software where you simply program "W" or "N" for a channel and that is it. Typically the channel spacing/bandwidth and deviation are related (ie narrow = 12.5kHz and 2.5kHz while and wide = 25kHz and 5kHz). The MTR2000 is a little confusing because it appears you can select the RX bandwidth independently of the TX deviation. Am I understanding the RSS correctly in that?
If that is the case, then does selecting 20-30k under Receive only mean that the receive bandwidth is that and as long as I set a Transmit deviation to 5000 Hz then my TX won't exceed 25kHz? This would mean that my TX at 462.7250 won't interfere with 462.7500, but if my RX is really as wide as 30kHz, I could get interference from channels 25kHz away?
Obviously the fact that you can select them independently and that the bandwidth under receive is a range confuses me as to what the MTR2000 actually will do.
