MTS2000 codeplug and programming help!
coshea92
UK
Hi all,
I know you are all very experienced in radios and I am hoping you can shed some light on something I am looking to do...
I have just purchased 4 MTS2000 Type 1 UHF 403-450Mhz radios from ebay
I have also purchased 1 after market RIBless cable from ebay aswell... (hoping this works)
I am in need of a code plug that I can use so all I have to do is put in the frequencies I want to use and write it to the radio! (I am new to this and dont want to bugger up my radios, but at the same time, I despise having to pay over 200quid for these radios to be programmed!)
Also I need help in how to program them, if someone could help me I would be much abliged.
Kind regards from the UK,
Skypilot007
Medford, NJ
You need the CPS for the radio if you don't have it already. You can get that from motorola or get lucky searching the internet and find a copy cheap or free.
Once you have that and a working cable that can connect to the radio you need to read each radio and save its specific codeplug. Then make your changes to the codeplugs and write them back to the radios without mixing them up. I beleive there is a cloning cable for the MTS2000's so you would only have to make one codeplug and clone the other radios from the original. You can also copy and paste most of the information from the one codeplug to another with the CPS. Either way you don't run into radio serial number issues when programming as codeplugs are serial number sensitive.
rescue161
KE4FHH
Hubert, NC
Be careful with the MTS2000 as if you use the wrong software, i.e., Lab RSS, you can Toolproof the radios, making them useless. Sure, you can get the software from the net, but do you really want to risk messing up your radios?
You can read about Toolproofing on The MTSX Series
As far as looking for a codeplug, it would have to be from an identical radio, i.e., same Flash & model number.
It's best to get the radios, READ them first and disconnect. Then save a copy of that codeplug to the computer. Then, make a copy of that codeplug and modify it. That way, you still have a backup of the original codeplug that you can fall back on if you bugger things up with the copy that you made.
b7spectra
EMS Dispatcher
Cobb County, GA
Also, make sure you have the latest version of CPS because if you have an earlier version than what the radio was last programmed with, you won't be able to program it.
coshea92
UK
All I can say so far is thank you! This has really helped me, I do have the CPS 2.00.01? I will do as it says above, hopefully I wont be able to toolproof my radios using this software and it looks much easier to use than the RSS!
Now just waiting for the radios to arrive, I have bought 4 and only need three, so will play around with the fourth one to get the hang of it!
Much appreichated
b7spectra
EMS Dispatcher
Cobb County, GA
Most of the CPS is really user friendly. Once it reads your code plug, the software will usually gray out options that are not available to that radio. Motorola must have had a new computer programmer design the CPS because it's bounds over the old DOS based sw.
coshea92
UK
Guys,
Thanks for your help so far, I have run into a little problem.
All the other 3 radios have programmed per my "main" codeplug which works fine... But one radio accepts the codeplug, but has like a nuisance delete noise??? (sounds like a scrambling) and just does this continually even when just switched on and on every channel! I get a code on the LCD saying I CSQ. Something I noticed about this radio is the flashport is 000002-000000-8 and not 000004-000000-6, the system package is H36 not H37 and also the firmware is 5.30 and not 6.02 like the other radios!
I have also noticed that there is a limited number of options compared to the other radios. Can someone please help me?
Warmest Regards.
coshea92
UK
Wow my life sucks at the moment!
But, the radio in the last post has now ceased to work... But I connected another one upto the computer via ribless cable and it suddenly sparked into life! Now back to 4 radios!
LCD didn't work, so took the working LCD out of the radio that doesnt work. So all works!
Programmed all the channels into it and it worked fine... until this morning, went to use it, selftest green LED came on but not the screen, transmits but... wont send any voice signal so speaking into it is useless. It recieves fine...
Any diagnosis?
