jody_clarke
Much needed input needed on base antenna setup & coax-Thanks so much for your input!!
For those of you who would like to tell me "Hey why don't you do a little research before you start a new thread" my reply would be I've read as much as possible due to very limited internet via my phone (16kbs down) due to tornadoes that have recently ripped through our county "Cullman, AL" destroying utilities and infrastructure, so please bear with me. On to my questions, for starters not that it matters our county and city police have recently switched over to p25 digital-VHF. Am currently having to use a mag-mount mobile antenna on metal roof to receive anything as I live in a rural area approx. 20 miles- line of sight (in a pretty steep valley no less) from where I want to be receiving most all of my radio traffic. The digital signals come in crystal clear w/ mag-mount on metal roof, while the other analog public safety, utilities, local airport, etc. am having trouble pulling them in w/out lots of static. Am looking for best option for wide-band omni-directional base mount antenna to mount approx. 5 feet above roof? Have used Radio Shacks dis-cone antenna w/ success in past but not at this location, have also seen folks referencing a scanntenna, or something to that effect, one made by comet, as well as other dis-cone antennas made by antennacraft-sp? My price range is $100 or less- are all these discone antennas (in the $70-$90 price range) about the same? Everyones suggestions are most welcome, the other question I had was I will be needing to run over 50 feet of coax closer to 85 feet am looking at some TerraWave TWS-400 -RG8/U low loss coax @$.59/foot with 1.2db losses @100 Mghz for a 100 foot run which actually has better signal loss values than there $.89/foot Belden 9914 from theantennafarm.com? Am wide open to suggestions on the coax end as well, don't mind spending a bit more for quality coax if need be as it goes w/out saying I simply want to retain as much signal as possible. Only other thing I can think to ask is If I'm not mistaken most antennas have a pl-259? connector while I'll need a bnc connector for the other end- is there a bnc connector that can be crimped directly onto the thick RG-8/U cable or will there be another adapter involved in that process? BTW- my newest and most used receiver is a RS Pro-106, will also occasionally be using an old AOR-AR8000, ICOM ICR1, and a RS Pro-84.
Thanks in advance for any input you can give me on any and or all of these inquiries as it's much appreciated, J. Clarke
