Multiple Scanners - One Antenna???
bigdaddyduke
from parts unknown (aka Maine)
I am wondering if there is a BNC connector that will split one antenna feed into multiple outputs for either mobile or base use. I have heard of using standard coax splitters but am wondering if there is one specifically for BNC for simplicity.
N
N_Jay
Guest
Yes there are BNC "T" connectors, but NO, that is the wrong way to do it.
Use a splitter.
If you want to spend the $$, you can get BNC splitters (usually called a multicoupler)
bigdaddyduke
Can you tell me why using a T is the wrong way? I wouldnt' want to use a T anyways as I want to be able to use 3 or sometimes 4 scanners off one antenna...just wondering why a T is the wrong way to go.
Thanks again
N
N_Jay
Guest
Thanks again
That's a 3 credit 300 level course called "Electromagnetic Waves and Fields" with a 1 credit lab on Propagation and Transmission lines.
KT4HX
Spotsylvania County, Va
Thanks again
In a nutshell, if you split the signal to multiple scanners without amplification then you are dividing the original signal level by a factor of how many splits you incorporate. In otherwords, if you feed four scanners with one antenna by passively splitting the signal then each scanner will receive about 25% of the original signal strength.
If however, you utilize an active multicoupler (amplification), then each output port of the multicoupler would deliver 100% of the original signal being fed by the antenna to the multicoupler. And thus each scanner would receive full signal level.
prcguy
That’s if you’re using a “splitter”. Using a “T” connector to split a signal to two destinations will have additional losses because the antenna will see around a 25 ohm load if two 50 ohm cables are used to feed each scanner. At least a “splitter” or “divider” will keep the impedance consistent throughout the system.
prcguy
ex8010
ex8010
i tried using a "t", but the scanners interfered with each other. I got a stridesberg multicoupler now. one of the best toys ever. I think it actuall makes the signal stronger
Winnsboro, La
antenna multi-coupler
There is a multi-coupler that will run 2,4,6,8 scanners from one antenna. you can search "multi-coupler" on this site. I'm pretty sure that there are a couple of posts on that subject in the antenna forum and one or more of them should have a link to companies that sell them.
N
N_Jay
Guest
prcguy
If it were only so simple.:roll: :lol:
