SDRPlay Multiple SDRUno instances running - separate shutdown
w8jfj
Central Michigan
I have two folders setup to run two instances of SDRuno for two different SDRplay receivers. However when I close one of the apps the 2nd app also shuts down. Is there a way to not have both apps shutdown together?
merlin
DN32su
Both apps are sharing something in common, maybe a driver that is shutting down the app you want up.
Could be both apps are using one SDRplay radio. Make sure those are on their own USB port and isolated.
