prcguy
I would not say that but the Omni-X probably works a bit better than a Discone on some freqs. Whether those freqs are where you concentrate most of your listening would have to be tested.
The Discone is not a bad antenna at all, it provides very consistent performance over most of its range and at the high end the pattern usually points up causing problems with 800MHz reception. Sure you can find antennas with much more gain than a Discone but you wont find any anywhere that cover the same omni directional bandwidth as a Discone.
The Discone also provides a very good match to the feedline over its entire range and if you use a preamp it will be less likely to oscillate or cause other problems compared to the same preamp on a spot tuned multiband scanner antenna.;
If the Omni-X works better than a Discone it would be beneficial to the seller if they could compare the antennas and document any improvement the Omni-X may have.
prcguy
prcguy
So would it be safe to say the Omni -X would not be a bad choice and will perform much better then even the most expensive discone.
I am leaning towards the Omni –X. I wound some additional treads and had good things to say, its size and frequency coverage are also appealing.
Unless someone has any other strong recommendations or opinions against this antenna I hope to purchase in the next few weeks.
