Mute unmute rule astro25 XTS VENTURA
cmdrwill
So Cali
The PL TX and RX is set on each personality, ie MODE.
STD/STD would be the default for a no PL RX mode. What AND/OR does is only Unmute the RX with a valid PL AND squelch opening. And with OR the RX mutes with the loss of valid PL OR a squelch closing.
STD/STD will unmute with a valid PL and force the squelch open.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Could the OP please repost the question so others can benefit from the answers posted here?
Thanks.
I've never understood this type of behavior.
Deleting your original question does a disservice to the community as it makes the thread completely pointless. Next time, leave your question so that it may possibly help another user.
Thanks.
I tried to delete the thread because I found out they're using different PLs. So my question was really invalid. I cannot edit the first post to put the question back to its original form.
My apologies for the confusion.
The question was which option to use under the unmute rule. As I usually use unmute and or mute option and I thought it wasn't working due to no audio coming through the speaker unless holding down the monitor assigned button. What was happening was the different sheriff units were using different PLs which would NOT unmute my speaker.
