kicktd
For those not interested in monitoring aircraft/ATC/ACARS see the bottom of this post.
I am new to making antennas and antenna termonology so just bear with me here :lol:
Well I wanted some better performance for the Civilian Air Band mainly for Louis Armstrong Intl. Airport (New Orleans) and for ACARS. So I found the plans for an ACARS antenna that covered the band I wanted (approx. 108-174) and went to make my own design based on the length of the antenna. Now I know I'll probably get nit picked about it but hey, it works great.
Total cost: $0. I used what I had around the house, 2 old aluminium lamp poles (1/2" in diameter) which surprisingly were the lengths I needed and provided an extra element (slightly smaller than the 1/2" main pole) which made a difference and helped pull in those weaker signals.
Here is a PDF with the design and measurements Here. The red lines feeding into the PVC T are the connectors for the 300 to 75 Ohm Balun I used. I used screws that came on the lamp poles to hold the ends in place and using needle nose pliers to close the fork around the screw for extra hold and contact support, making sure to seal them with some weather proof sealent.. The main "pole" faces up and down just like in the PDF. I Held the antenna while rotating it slowly to see which direction would work best and this position gave the best results.
I will post a picture of what it looks like on my antenna pole. So far at around 15, 20ft tops I am getting ACARS transmissions as far away as 340+ Miles as the crow flies. I am picking up planes locally (around 60 miles to KMSY) all the way down and with tower clear as a bell. Ground frequencies are there but can't make anything out and I plan on raising the antenna up higher today to see if it gets better reception. Also I can faintly sometimes make out the actual ATC transmissions from 60+ miles from the tower and hoping that improves also with raising the antenna.
Over all for a "free" antenna it sure is kicking the butt of my $25 RS 20-176 (same height etc.). I would be lucky to hear New Orleans APP/DEP Aircraft from where I am at with the 20-176, and it would be mixed with lots of static, never could hear aircraft on the tower frequency either.
Also for those not interested in aircraft/ATC/ACARS this antenna does an OUTSTANDING job for the conventional public safety band. Picking up stuff that use to come in with static with the 20-176 CLEAR now with my home brew antenna.
Edit: Here is a picture of how it looks. It's the Antenna on the left. It's gray and rainy here so it makes the image look awkward and like it's not level. Also makes it look like the 20-176 elements are close to my home brew but they aren't.
