prcguy
I have several commercial lab type log periodics from Electro Metrics, Singer, Racal and all terminate in an unbalanced RF connector and some have a string of ferrite beads on their internal coax harness to isolate the antenna from the outside world and unbalanced feedline. These are not cheap ham or scanner logs, but higher end units for the measurement community and designed to use as is with no external baluns.
As Mr. Wienke mentioned, a good common mode choke balun will isolate both the center and shield of coax when you compare the input to output side of the balun. If it doesn't, then is not a very well made choke balun.
One way to describe a balanced feedline is each parallel run conductor is RF isolated from ground or each other. If you take a coax feedline that is grounded and obviously unbalanced, then feed that through an effective 1:1 choke balun, then you will RF isolate that coax from ground, from the unbalanced input and meet the criteria of a balanced feedline on the outout side of the balun.
prcguy
prcguy
It will only isolate the shield, stop any current running outside of the shield. You can do that by using toriods or coil up the coax that will inductivly shortcircuit the shields on each turn cancelling out any RF. You have to do that when something is wrong in the antenna system and you get RF on the coax shield.
You must use a transfomer to connect a coax to any type of balanced antenna. All log periodic antennas are balanced.
If you connect a coax directly to the booms of a log periodic antenna it will no longer function as one.
You can stick any metal up in the air and it will receive signals. More metal will receive more. Scanner antennas are often advertised as having a 25MHz-1000MHz range and it will actually receive all frequencies, if the signals are strong enough. When you connect a coax to a balanced antenna without using a balun transformer you will receive signals but the antenna will not perform as it was designed to do.
/Ubbe
