A little background first: I'm a 30 year+ amateur radio operator. I also managed a commercial two-way radio system for several years--over 100 mobile and portable radios, 6 base stations, and two mountaintop repeaters, using both analog and digital (NXDN) protocols. So, I've spent a lot of time around both commercial and amateur radio equipment.
Now, my two pet peeves--the first applies to both amateur portable and mobile radios, the second applies to portables:
1. Lack of 2.5 kHz step spacing on nearly all amateur VHF (2-meter) radio equipment. Why is this a big problem when most all amateur 2-meter communications use 5 kHz channel spacing? Well, because most amateurs ALSO use their amateur radio equipment's extended receive capabilities to monitor non-amateur radio channels that may (and more increasingly do) use the 2.5 kHz "splinter" channels created by the "re-farming" of the commercial VHF spectrum in 2013. There are only a few of the Japanese radio manufacturers that offer ANY 2-meter models that are 2.5 kHz step-capable. Most Chinese radios offer 2.5 kHz step capability, but many of those radios have other quality issues or other shortcomings that make them unattractive. Most all of the Chinese and many of the Japanese radios also have what I consider a major second flaw that I discuss below.
2. Inability to lock the keypad, PTT, and function buttons when the portable radio is in scan mode. Why is this a big deal? For both amateur use and monitoring of non-amateur radio channels, many amateurs want to monitor multiple channels using the radio's scan function. However, without the ability to lock the keypad, etc. while scanning, the user can inadvertently bump the keypad, PTT, etc. while carrying the radio on his/her belt, etc. and knock the radio out of scan mode without even knowing it. The commercial portable radio manufacturers have long ago realized that this can create an inconvenient and even dangerous situation for the user, so many commercial models allow the radio to be keypad-locked while in scan mode.
I talked with numerous factory reps of the radio manufacturers about these issues and they agree that it is a problem, but nothing ever gets done about it. So, why don't I just use commercial radios? Well, I do, except for one big issue. I have need to monitor both VHF and UHF commercial and amateur radio channels, and none of the radio manufacturers (Chinese or Japanese) produce either a commercial or amateur portable radio model that I know about that addresses BOTH of these issues.
I would appreciate others thoughts on this and if there IS a dual-band portable radio that addresses both of these issues out there, I'd like to know about it. Thanks.
