My Updated Shack
squadman
Lebanon, PA.
Here is my updated Shack,
On Headboard - BC248XLT
Mounted under printers - 2 Pro 2055's
Antenna's are from Radio Shack on the bottom and the other is for my Nextel Amp.
dangitdoug
Where did you find those antenna mounts?
How is the ground plane performance on them?
Doug K
squadman
Lebanon, PA.
Doug K
Those are book ends I picked up at Staples. Performance is Ok with them, I wouldn't mind trying to figure out how to ground them for better performance.
dangitdoug
I use a magmount on the windowsill. The frame under the paint is metal and gives a good grounding surface. I am keeping an eye out for some scrap metal that will fit the window frame. I may consider having a piece custom cut to fit across the entire width of the window if I can find someone working in a shop.
Doug K
Gilligan
Hagerstown, MD
Can you give some details on the nextel amp? I just got nextel and I love it, but I'm curious about this amp in case I need more signal in the future.
those radio shack "All Band" Mobile antenna's are Grounded through the Coax into the Radio. I tore one apart once to get the magnet off to perm-mount it to a car. Nothing on that antenna touches the magnet, which sticks to your car. Or in you're case, Staples Book-shelve ends. (Nice!)
