MyGMRS Database is Whacked
RFI-EMI-GUY
FYI If you have a repeater over on the MyGMRS Database it is whacked. I found mine attached to wrong frequency and did a cursory look at other repeaters that had their KHz in the name like, "Podunk600" (made that up) and those were off.
I think the site has been hacked. If you have a listed repeater, double check the actual frequency that is listed.
RFI-EMI-GUY
From what I can tell the damage was done after May 2nd 2021. Most likely 6/21/2021 when I show a change in the weekly repeater update.
Hans13
Thanks. Off to check.
ETA: Thank you again as ours was the wrong frequency.
