ok I won,t ask anymore!! Marcy
Ask the questions !!!! If a person doesn't want to see your posts they can set you to ignore. There will be times though where people don't know the answers 😀
As
@wsmoore said, ask the questions, my point was not that you shouldn't ask but rather with a little leg work and use of the search feature in RR and the forums many of the answers can be found, that is part of the fun of this hobby, learning and discovering. Then, if you run into a dead end ask the questions.
For example, a search of that frequency in RR would have pulled up a list of Federal Prisons and it would have given you another avenue to look at other than CAP. Learning how the searches work will help you to discover new things all the time.
Meanwhile, if you can find the rest of the info on the system, and verify it is P25 & Danbury, perhaps you can submit the change to the database as Danbury is still listed as Motorola Type II. Many FBOP facilities are changing from Type II to P25, looks like you found another one. Great catch.
