Nags head
wvufan
West Virginia
I will be going to Nags Head soon, and I'm wanting to pick up the coast guard. I have never been to Nags Head and have never tried to scan the coast guard either. So I need a little help. Does anyone have any frequencies for them or do they use marine channels. Also, how active is the coast guard in the area. THANKS!!
hill
Middle River, MD
Nags Head
The CG should be easy to monitor from the Nags Head Area. The CG mainly uses VHF-FM Marine Channels and some are listed as CG channels in the bandplan. Not being in that area, I don't know which channels are use down there. here are the channels.
channel 16 156.800Mhz calling and distress
channel 22A 157.100Mhz CG to public
channel 21A 157.050Mhz CG working channel
channel 23A 157.150Mhz CG working channel
channel 81A 157.075Mhz CG working channel mainly oil spill ops
channel 83A 157.175Mhz CG working channel
You will have plug them in the scanner to see which ones are being used in that area, since they rotate them in each area. The channels are rotated, so not to interfer with other close by CG units.
You should also put some of the pleasure boater channels in the scanner, since there should be alot radio traffic on them this time of year.
Hope this helps and let me know what you received on your trip.
Larry
jeffmulter
Fort Mill, S.C. (just south of Charlotte, N.C.)
wvafan - Since you'll be visiting Nags Head, I would suggest visiting the USCG station at Oregon Inlet after you get settled in. The station is about 10 miles south of Nags Head, on Hwy 12.
Except for the general broadcast messages on marine channels 16 and 21, any boat transmissions you will hear on VHF will likely come from units stationed at Oregon Inlet, although the range of your reception will be limited.
If you can strike up a conversation with the personnel on duty, and explain that you are simply on vacation and looking to hear some local USCG communications, they may be very helpful about which marine channels to monitor, and what assets (water craft) are currently assigned to the station.
Make sure you bring a copy of the marine channel numbers and frequencies with you on your trip, as most folks do not memorize "frequencies," but they do remember channel numbers.
Besides the Oregon Inlet station, the "group" headquarters is in Buxton, and there are also stations at Hatteras Inlet and Ocracoke Island.
USCG aircraft will generally come out of nearby Elizabeth City, so you might want to do some research on current VHF and UHF air channels for the CG in District 5 or nationally.
Oregon Inlet is also an operations base for commercial fishing and day-trip fishing boats, so a little time spent searching the marine channels there might yield some good frequencies to monitor.
Bodie Island is the name for the section of the Cape Hatteras Seashore along Hwy 12 that you'll travel. Along the way, you'll past a communications tower that is used by the Navy and other entities, including U.S. Customs. You might want to plug in 165.2375 and give it a listen.
Jeff Multer
wvufan
West Virginia
Thanks for the info guys. It looks like there will be a lot to monitor. I'll be leaving in about to weeks and can't wait.
jeffmulter
If, by chance, you also are interested in AM DXing, the Outer Banks is also a great place to log AM broadcast stations from the northeast U.S.
During the middle of the day, you'll be able to hear numerous stations from the NYC, Phila / S. Jersey markets, and New England ... much of the signal path is over water.
I was "born" a Yankees fan, and there's no greater way to pass a nice afternoon than sunning on the beach and watching the stollers (not the "word" I was going to use, but I wanted to keep it P-G) pass by, with the ballgame playing on the radio.
Jeff Multer
jeffmulter
This might be too late for wvufan, but I ran across this in my files today. I don't have a date for the information, but it might be of interest to someone headed to the Outer Banks:
US Coast Guard / Air Station Elizabeth City Helicopter Pre-Sets:
01 381.800 11 372.100
02 355.600 12 389.900
03 349.100 13 279.200
04 358.800 14 281.800
05 233.700 15 268.700
06 251.600 16 374.900
07 340.200 17 255.400
08 360.200 18 243.000
09 323.000 19 383.900
10 349.000 20 282.800
( also check 277.800 / Navy "common" channel for traffic )
Jeff Multer
