bezking
Anybody have any idea if NCPD is upgrading their /\/\ Sabers when they move to the 500 MHz system? If so, is it known which radios?
bezking said:OK, so I need to get a BCD996T or PRO-96 now.........
I don't think that is going to help you at all.bezking said:OK, so I need to get a BCD996T or PRO-96 now.........
You gotta wonder why they need to use up 500 MHz frequencies when the FCC gave 'that side' of the Hudson exclusive use of Channel 16 (482 - 488 MHz). That's 240 12.5 kHz wide exclusive channel pairs. In my mind, channel 19 (500 - 506 MHz) should have stayed exclusively on the west side of the Hudson. But what do I know?!crashcrew said:I wouldn't hold my breathe waiting for the 500 mhz system, it's been in planning since 2004
vsny said:scosgt,
Trouble hearing the 2nd and 8th ??
I don't know if it's the system or not but all I heard today (Tues 5/22) was complaints on the Nassau PD radio of poor reception no matter what channel I scanned.
902 said:You gotta wonder why they need to use up 500 MHz frequencies when the FCC gave 'that side' of the Hudson exclusive use of Channel 16 (482 - 488 MHz). That's 240 12.5 kHz wide exclusive channel pairs. In my mind, channel 19 (500 - 506 MHz) should have stayed exclusively on the west side of the Hudson. But what do I know?!
I thought NYC's implementation on 16 was 11K2, I see your point about adjacent channel issues with 20K0. You'da figured that the FCC would have required 11K2 right from the initial implementation.CloroxCowboy said:If you take a closer look at the TV16 band, you'll see that the vast majority of the bandwidth is licensed to agencies in NYC. NCPD has use of five channels (I think its five) which are currently used for mobile data. Narrowbanding the current NCPD channels in TV16 will not be enough, not to mention what would come of the units needing the lost data coverage. It is a physical impossibility for NCPD to use the narrowband channels in between the wideband assignments licensed to NYC.
That should be a simple search. There is literally someone on and adjacent to everything (in other words, don't even submit an application unless it has all of the LOCs from co and adjacents attached).This is not really debatable because the NCPD had to prove to the FCC that there were no other available channels in any band before they could be issued a waiver to operate in TV19 (500-506).
Most of the NJ systems were designed around small AOPs and implemented "right-sized" instead of over-ERP to cover their communities. This was a big departure from VHF and the 453/ 460 legacies. To my knowledge, I can't see most NJ Ch. 19-based system's 21 dBu contour extending past the Queens/ Nassau border. There may be one channel on Fort Lee high-rise. The rest are relatively low HAAT.The reality is that with NYC not using any bandwidth in TV19, it is quite possible for agencies in Nassau County sharing the airwaves with New Jersey. I do not know of any problems between agencies on Long Island and NJ--currently--regarding the use of TV19.
Well, even though it's not "coordinated," the processors still receive the application, chances are that the one who did the search justification for no frequencies available was a coordinator or local advisor and someone still has to do an engineering study. You can't send that directly to the Commission or enter it ULS without going through one of the coordinators (I could be wrong, but I don't think so... I haven't dealt with T-band since Form 574's). My only direct filings have been on 700 (we have that out here), 4.9 and DSRC.And, you know what the most interesting part of this is? Since all of the TV19 licenses in NY and northern NJ are on waivers, they were all exempt from frequency coordination (APCO, IMSA, etc.) yet it all seems to work.
My suggestion is NOT that coordinators are not needed. They are. I am implying that they could have done a better job in the bands that they do coordinate.
