Nationwide Freq.
datainmotion
Colorado
If it's in the database here, any software that will interface with RR will download it. Others can be done via cut 'n' paste as well.
"Nationwide" channels are commonly part of the "interop" lists on many of the individual State DBs here as well.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
If you can't get it using FreeScan's web import, you can use the EZ Grab function...that software is used with the Uniden DMA scanners
best regards..Mike
MtnBiker2005
San Diego County, California
The above question hasn't really been answered yet...
Is there a list of programming software that is working with the latest Web service Version 9.
"Nationwide" channels will only show up if the programming software is using version 9 ? correct ?
So in datainmotion above post. It should read "Any software using version 9 code".?
http://wiki.radioreference.com/index.php/RadioReference.com_Web_Service3.1
datainmotion
Colorado
I don't see a "Nationwide" selection in Win500 2.02 and per their website, it doesn't look like 2.03 does either.
DonS
Franktown, CO
Win500 2.04 supports it. "Nationwide" appears in the list of States (sorted, unfortunately). When you select that item, it will populate the Agency list just like it does for actual states.
EDIT: and now the current releases of Win96 (1.72) and Win97 (1.35) support it.
