Does anyone else listen to US Navy Ships? I've found that most use the same set of frequencies and talk group assignments. This causes a problem when two ships with the same data are in port at the same time.
They are not using a Smartzone system. Here are some problems:
1. If both are using the same control channel at the same time, each ship has to compete for control over it's radios.
2. If they aren't using the same control channel, then they still have to compete over the other frequencies.
3. A good portion of the time, I see ships that only have ONE user ID for every radio on the ship. Big problem if a radio is ever stolen. If they needed to inhibit the stolen radio, they'd end up wiping out every radio on the ship...
Why did they do the systems like this?
