need help from people from il
raymondjtoth
des plaines il
hi name is ray toth i work at jewel-osco were can i find the scanner radio freq for jewel-osco any place like to hear whats going on with company from delivery and so on im a bagger so can keep up and know whats going on in case some one ask me thansk ray toth if can help im in desplaines il
tvengr
Well Known Member
Baltimore County, MD
tvengr is walmart in radio ref wiki?
The one in my area uses 154.57. That is one of the 5 MURS frequencies.
MURS comprises the following five frequencies:
ChannelFrequencyMaximum
authorized bandwidth
Channel name
1151.82 MHz11.25 kHzMURS 1
2151.88 MHz11.25 kHzMURS 2
3151.94 MHz11.25 kHzMURS 3
4154.57 MHz20.00 kHzBlue Dot
5154.60 MHz20.00 kHzGreen Dot
Channels 1–3 must use "narrowband" frequency modulation (2.5 kHz deviation; 11.25 kHz bandwidth). Channels 4 and 5 may use either "wideband" FM (5 kHz deviation; 20 kHz bandwidth) or "narrowband" FM.[4] All five channels may use amplitude modulation with a bandwidth up to 8 kHz.[5] MURS falls under part 95 and was not mandated for narrow-banding, such as those of Part 90 in the public service bands
chill1971
Opdyke, Illinois
Walmart channels
1 154.5700 CSQ
2 154.6000 CSQ
3 151.8200 131 DPL
4 151.8800 131 DPL
5 151.9400 131 DPL
6 154.5700 131 DPL
7 154.6000 131 DPL
ilgrant
Chicago, IL
The frequency range cubn provided will do the trick. Lots of big box stores are in this range. You will have to be within a half a block to hear any of them, though. Common stores you may hear are Home Depot, Target, Jewel/Osco, Portillos and on and on and on.
K9DAK
Wauconda, IL
The Jewel in my town uses 900 MHz spread spectrum Motorolas (model number escapes me)... not monitorable by any scanner.
