Hi again I and all,
We have a sticky wicket here, you say you have a license but it appears the Mississippi Valley Council holds it and Jerry Walker of Laguna Hills CA is the trustee. Under the terms of the license grant there is no base (fixed) station listed, only mobiles. While the Council is the licensee it's actually the transmitters which are licensed so a fixed station would constitute transmitting without a license.
Putting an antenna atop a tower is a bad idea but a temporary fixed station MAY be allowed (I don't see a TB listed) using an antenna put up and taken down easily. Say for example on a temporary roof mount as needed you MIGHT get away with. I'd look more closely at the terms of the license grant if I were you to keep the BSA out of trouble with the FCC and you out of trouble with the BSA.
