Need help programing VX 160
CRV75158
Scurry Texas
I have a vx160, usb programing cable, ce44 software and laptop that is running on windows XP. I have reduced the baud rate to 1200, reduced the trans/rec buffers to minimum and tried with and without the FIFO buffers on, but can not get he radio to upload. I have gotten the program to bounce between "Please wait" and "retry", but eventually goes to check to see if you connected to the com port. Is there a certain procedure or setting that I have missed? Any imput or help would be appreciated.
62Truck
Ordinary Subscriber
Uranus
I am having the same issue..I ran read the radio with out a problem but trying to write the radio is the issue..if you seem to get it work please let me know.
ambdrvr
Vertex VX-160
Hello,
If I remember correctly the CE44 software is DOS based software and probably doesn't have very good support for the USB cable that you are using. I don't really have an answer for you as I have not used the USB cables, always the DB9 cable. Maybe you can try to rename your USB port to port 1 (that should be what the software is looking for) and try it that way. If I am correct and CE44 is DOS, maybe try using an older computer with Win98 on it.
That's just my 2 cents worth. Hope it helps.
Ambdrvr
62Truck
Ordinary Subscriber
Uranus
Thanks for your reply ambdrvr..they have a windows and a dos version of CE-44..I can currently read the radio with no problem..but how ever when I write the radio it starts writing, and half way through it downloading it hiccups and doesn't program. My VX-354 which uses CE-86 I use a USB cable for and it works..I only get issues some times, I just have to restart the program and its fine, and as for using a DB9 I wish I could but my laptop does not support that.
aka123
I hade the same problem but found a new ver of ce-44 for windows vista and it works great with xp..If there was a place to upload software I would share it but cant seem to find a spot to upload..if I ever find that site again I will share It..well found it and here it is...
hxxp://www.radioscanner.ru/files/vertex/file7294
62Truck
Ordinary Subscriber
Uranus
Hmmm I wonder if it will work for XP if its for vista..well I downloaded..when I get a chance I'll run home and grab my 180 and see if it works
62Truck
Ordinary Subscriber
Uranus
Tried it a few days ago and was able to read and write my 180 with no issues.
undertakeru
texas
I have had the same problem with windows vista, Thank you for the Vista version C44 software :)
sdmrt18
Woah! I've been having that problem with a VX-180 for months now. Thanks aka123.
