Need Help Programming
way71
Houston Texas
I bought this scanner off of ebay not knowing anything about them,its a realistic Pro-41 handheld.Well Ive had in on for 2 days and havent heard anything.Can anyone help me,looks like I might need to reprogram it but dont know how.Thanks
mciupa
Canadian DB Admin
Moderator
I'm here a lot
Hi way71, welcome to RadioReference :)
If you like Public Safety monitoring, click on this link for Houston from the database: Harris County, Texas (TX) Scanner Frequencies and Radio Frequency Reference
The two columns you would be concerned with are frequency, enter that into your scanner and then take a look at the description column so that you know what you are monitoring.
While you are there, check out other entries for Harris County, looks like there is a lot to listen to. :)
way71
Houston Texas
Thanks for the help guys,I got HFD programmed on channel one so far,do you know if each channel can hold one freqency or is it multiple frequencys,Thanks again
