Win500: need help understanding p25 programation
RabbitSlayer
need help about p25 and trunking programation i live in NB canada the province juste turn to p25 phase 1 in my region i did find some info on radio reference about the new frequencies but i dont understand the programations thx to anyone ...i have psr 500 but not working properly i will buy a new one whatever it takes
BC_Scan
Vancouver BC
First off you need to know what control channels you can hear from your listening area
so search between say 768-773 MHZ and listen for control channel noise (others describe it as machine gun sound) ,strong carrier/or weak depending on area, make note of that,
than you need to see what other freqs are associated to that using this:Maritime Public Safety Radio Network (MPSRN) Trunking System, Various, Multi-State - Scanner Frequencies
than you need to input them in your software as a new p25 trunk (your handheld will do this) than scan search one bank at a time till you hear traffic.
Put them in a seperate bank each control channel you find, could only be one depending on your location ,than listen , Good luck , consider this as well as required reading for your scanner
Easier to Read Pro-651/652/106/197 - WS1040/1065 - PSR 500/600 Digital Scanner Manual
Moderators consider moving this to the Atlantic/Maritime forum to be able to assist this person a little better with localized knowledge.
