There is a LOT to monitor in El Paso County, for now the 2 SO Dispatch TG's are clear. There is a huge amount of Fire Talkgroups, plus EMS, plus a lot of other stuff. However the UV-5R is utterly useless. If you are looking for a very low cost option, you could always get a couple RTL SDR dongles and DSD+ or other P-25 SDR decoding software. However, that will only work on a computer.
If you want an actual scanner that works for the springs, your ONLY option is the SDS100, that's the only scanner that supports simulcast. (Much of the springs is covered by a very wide-area multi-cell simulcast system. There are other non-simulcast sites, but you would be missing a lot if you can't monitor the main simulcast site; a massive number of radios in the springs affiliate it.)
