ProScan: New at ProScan
LL59
I have a Uniden BCD536HP scanner connected to my router using the dongle. I have ProScan installed on my laptop and running ok as long as I'm in the house on the network. I have been trying to setup so I can operate and listen to the scanner at work. I am not good at setting up computer systems. I'm trying to setup port forwarding but having problems. When I take my laptop to work with me, will I be able to connect to my router and it will the connect to the scanner, or do I need a computer at home with the ProScan running on it? My laptop is a HP running windows 10.
freqseeker
Puget Sound WA.
You will need a computer running ProScan at home connected to your BCD536HP.
Check out the following links at the ProScan website. Very well written by Mike a member here @NYRHKY94
ProScan webserver.
ProScan RSOIP
The ProScan license is generous and allows you to use one license on two different computers (thanks Bob). Using the webserver you only need a web browser on the listening computer or smart phone.
If you need further assistance plenty of us can help out.
LL59
I got ProScan load and setup on our desktop computer at the house now, and got the port forwarding setup and working on my laptop off the house network. To get the audio to work I have to un check the loopback box in audio control section under the monitor & test tab. Is this right or do I have something not setup right. My next question is, with the desktop running ProScan and trying to use my laptop on the house network it is not allowing audio over both computers at the same time. It swaps audio from one computer to the other. From what I was reading you only connect one computer to the scanner. Is their a way to connect my laptop to the server-desktop computer so I can get audio on both when on the same network?
