XPR New feature for TRBO CPS2
PACNWDude
Thank you for sharing. I try my best to put CPS 2.0 out of my mind, as every version has some sort of hex error and impacts aliasing in my own network. Grant I am combining ASTRO and Trbo digital via analog and Zetron IP interfaces. But, this feature might be useful for larger sites with many contacts that need to be imported.
KD0NDO
That's awesome. I'm still trying to figure out what the big deal with cps2 is. I have been hesitant to upgrade to it because all I ever hear about is how horrible it is. For a hobbyist is there really enough of an issue that I shouldn't upgrade?
Firebuff880
Boynton Beach, FL
The issue is that CPS 2.0 is an after thought. The plan was to EOL CPS and only support RM so when the masses rebelled a CPS 2.0 was born with a new "modern" code base and without some of the features of CPS. If as a hobbyist you are happy with what you have then no need to move forward and pay for what was once free (SUM) but if you want any of the recent enhancements to TRBO, like Talker Alias then you need to move forward. Also, if you send a subscriber to depot for repair when it comes back it will be on "current" firmware and you will have to move forward.
  • Like
Reactions: wdz
KD0NDO
Good to know, thanks. How exactly does RM work?
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
RM looks a lot like CPS 2.0, but it is in a client / server setup. It helps if you maintain a lot of radios and if you want to program/update radios over the air or over wifi. I have some mining and power generation/distribution customers who have huge systems (above 40 sites) and above 10k radios. Managing these systems would be a major pain without RM. For example, want to add a channel or make a small change in a few thousand radios? In old days, you touched each radio. Now I push it over the air or over wifi. TT
