New guy here
BrownCow101
Cass City Michigan
Hello, I got a cobra 29. I’m trying to hook it up to my old dodge truck right to the battery. The problem is I don’t really know where to get some good 10 gauge wire. I also am terrible at soldering outside at 30 degrees. I could use some all around general help.
10 gauge wire is kind of big for a stock CB. Are you planning on adding more radios? 12 or 14 gauge wire would be sufficient for a stock CB.
Don't solder connections, that makes them inflexible and leads to breakage. Use crimp connectors, and get a suitable fully cycle crimp tool if you want reliable connections:
Run the positive to the positive battery terminal. Use a fuse at the battery to protect the wire run.
Do NOT run the negative all the way to the battery. Instead, ground it near the radio to the body steel.
BrownCow101
Cass City Michigan
Thank you. I’m probably going to change the wire out anyway if I can fine some higher quality that will quiet engine noise. Currently the set of wires do not even power on the radio. The radio does work in a cigarette lighter. I know I’m lacking in power because when I key down the lights dim.
For crimpers I have a heavy duty set for doing power lines. A little overkill but the wire will never come off if that’s the route to go.
My antenna is a Stryker Sr-A10 magnetic mount to the roof of my truck. On a normal day I’ll barely reach 2 miles of empty field.
slowmover
Fort Worth
Noise thru 12V line and antenna coax should be distinguished one from the other.
“Most” seems to be from coax (engine-running).
Heat-shrink marine grade termination's
Split-loom to cover. ATC-fuse at BATT positive.
Build a harness capable of being removed similar to OEM.
RE same subject in big trucks with relevant commentary for cars:
Detailed discussion
