new member
jloriginal
calgary alberta canada
Im in Calgary Alberta Canada. Ive upgraded from an old 10 channel bearcat to a motorola psr600. Ive been able to input some Calgary police frequencies into the scanner I guess in conventional mode, but no matter how much I read the owners manual, I just dont understand what talk groups actually are. I dont understand how to find talk group IDs. I also dont understand the tgrp and tsys. Any help someone could give me would be greatly appreciated
Macomb, Michigan
Here is some basic information Trunking Basics - The RadioReference Wiki
You can also ask questions here in this forum for your area. They can help you get acquainted more with your scanner. Your PSR 600 isjust like my Pro 106.
http://forums.radioreference.com/prairies-pacific-coast/
jloriginal
Thank You
I appreciate your fast reply. Ill check this out. Im finding like anything else, the more I use it the more Im getting to know but there is so much to learn.
jloriginal
talk groups
Im sorry I seem very ignorant about these topics, but what exactly are talk groups. How are they different than listening to conventional scanned frequecies
Macomb, Michigan
A Talkgroup is the term given to assigned groups on a trunked radio system. Unlike a conventional radio which assigns users a certain frequency, a trunk systems takes a number of frequencies allocated to the system. Then the control channel coordinates the system so talkgroups can share these frequencies seamlessly. The purpose is to dramatically increase bandwidth. Many radios today treat talkgroups as if they were frequencies, since they behave like such. For example, on a radio scanner it is very common to be able to assign talkgroups into banks or lock them out, exactly like that of conventional frequencies.
In radio communication, a conventional radio is generally understood as being a system in which each group of talkers is assigned one frequency. This is usually contrasted to a trunked radio system, where talkgroups share a given group of frequencies.
fmon
Silent Key Jan. 14, 2012
Eclipse, Virginia
Adding to Oslo's comments.
A Trunk System is a combination of shared freqs (TSYS Object) and shared talkgroups (TGRP Objects)
The controller (CC) finds an unused voice frequency (VC) to match the user radio when keyed up with his/her assigned talkgroup (TG) to communicate with another user having same talkgroup. They are able to change the TG to a tac channel with a switch. Dispatch TG is used the most by all users of each agency (Law/Fire) etc.
The idea for your scanner is to place all CC/Alt CC in the TSYS freq section with TGRP's mapped to this TSYS using selected scanlist rather then banks.
A Programming Shortcut is in link below my signature but software is the easiest method.
However, OsloViking might present a very strong argument for manually programming.
jloriginal
It sounds like you guys have been doing this for a while. How do you find these talk groups to put them together. At this point all Im really interested in is getting to hear Calgary police service frequencies. My father retired from Los Angeles Fire dept and weve always had a scanner in the house, but they were so simple.Im really trying to understand what you guys are saying, but its not sinking in.
NWI_Scanner_Guy
SCANNING THE AIRWAVES SINCE 1987
Hammond, IN
I can't give you expert advice like you've been given already, mainly because I still fumble thru some things concerning my PRO-106 (which is the RS portable version of the 600). What I can tell you however is to hang in there and read, read and read some more. I found that the more I read the better my understanding of the radio became. Still had to ask some (stupid) questions, but was always given good advice that always seemed to work just the way it was supposed to.
One thing I didn't see mentioned was the Easier To Read Pro-106/197/PSR500/600 Digital Scanner Manual. That might help some as well.
Good luck and welcome to the RR.
jloriginal
Thanks again
You guys are really helpful. I only downloaded the software that came with the psr600. Ive heard about arc500 but dont know anything about it. Ive heard theres a way to copy & paste frequencies from a wbsite. This is a really good site. im glad I joined it
Highpockets
Toms River, New Jersey
Take a look at this software package (30 day free trial)
Win500: PSR-500, PSR-600, PRO-106, PRO-197, PSR-310, PSR-410 Scanner Software for Data Management, Monitoring, and Control
And this Guide will help you import from RadioReference to the software and upload to your scanner:
WIN500 - UtahRadio
fmon
Eclipse, Virginia
WIN500 - UtahRadio
Using Steve's suggestions and your premium subscription you can import Calgary police to Win500, edit the LED settings, save then send to scanner.
This is the data page, Calgary Digital Radio Trunking System, Calgary, Alberta - Scanner Frequencies
I imported police and fire talkgroups (171 of them) plus all 17 control frequencies.
Macomb, Michigan
Can anyone tell me how to post an icon with your name on here?
Click on usercp which is located up at the top left below the home tab.
And scroll down the left side and you will see different thigs you can do. There will be one that says edit avatar. There is where you choose to put an avatar that you choose. Make sure you save it.:D
