I hope I'm wrong about this, but I'm afraid that many Sedgwick County scanner listeners may be in for an unpleasant surprise as the new P25 system comes on line.
This new system is a 10-site digital simulcast system, which means that all 10 transmitters will be transmitting the same thing at the same time on the same frequency. In general, the current generation of scanners do not handle DIGITAL simulcast signals very well. (they seem to do OK with the current 6-site ANALOG simulcast system)
Unless you are close enough to one of the transmitters to drown out the signals from the other 9, or have installed a special antenna to block out all but one transmitter, monitoring this system may be difficult.
If you're not familiar with "digital simulcast interference", the symptoms are wildly fluctuating signal strength indications, as well as high error rates on the control channel and garbled/choppy audio on voice channels, even with what appears to be a strong signal. While the receivers in the "real radios" can combine the signals from multiple transmitters, the receivers in scanners just get confused while trying to PLL-lock onto a single transmitter, and they see the signals from other transmitters as multipath interference. (There have been many other discussions about this issue in other threads on this forum. Just search for digital simulcast interference.)
I had big problems with simulcast interference on my Butler County scanner feed. I started off trying to get by with a normal 800MHz scanner antenna. Depending on weather/atmospheric conditions, some days it would sound great, and other days you couldn't hear a complete transmission. Moving the scanner just a few inches would drastically change its reception. I finally installed a corner reflector antenna on a tower and pointed it at the Andover site (the feed scanner/server is in Augusta). It hasn't missed a word since.
Here's a link to a pic of the corner reflector running the Butler County Area Emergency Services feed:
http://s30.postimg.org/td4hpzpkh/Corner_Reflector.jpg
I'm trying to get my hands on another 800 MHz Corner Reflector for the Sedgwick County Law Enforcement feed. Also looking into possibly building one. At any rate, I hope I can get something worked out before they throw the big switch, and it sounds like I may not have much time!
Good luck!
ks13645
