DSDPlus New socket error
D
DaveNF2G
Guest
Latest FL release, Windows 10x64
Command lines:
FMP24.exe -i1 -o20001 -P0 f464.1500 -f
DSDPlus.exe -i20001 -o1 -e -fr -O NUL
After DSDPlus starts, FMP24 reports
"Accepted local connection on port 64725
TCP error = 10035
A non-blocking socket operation could not be completed immediately
Listening on TCP port 20001"
DSDPlus does not decode anything when FMP24 is showing a signal on the spectrum display.
I have been running this configuration for some time, through several versions of DSDPlus and FMP24.
D
DaveNF2G
Guest
Follow-up - the problem seems to center around FMP24 and TCP linking. DSDPlus works fine when fed via virtual cable from an SDR that is controlled by other software.
slicerwizard
Toronto, Ontario
Sounds like a new DSD+ with an old FMP24; that combo usually triggers TCP errors.
Hm, hello Notes.txt - latest DSD+ version is 2.186, most recent FMP24 is 2.52
