I was considering a home patrol 1 will that currently pick up ft worth arlington sorry I am going to get myself more familiar with this language and info....
The HP-1 would get the unencrypted talkgroups on FWRRS, which would include FWFD, most of the smaller Tarrant County cities & suburbs, as well as Tarrant County itself. Currently, most of the Tarrant County cities are using P25 Phase I, which is noted by the
D in the mode column by the talkgroups. However. the HP-1 would not work for Arlington. Arlington is using P25 Phase II, which the HP-1 cannot handle. Also, Arlington PD is fully encrypted, and I believe some of the FD as well. Some time back, it was reported that Arlington was going to encrypt their Fire channels (their PD channels were encrypted when they moved to FWRRS and started using Phase II). I normally cannot hear Arlington from home, but whenever I am in range for them, I never hear their FD. No scanner will be able to monitor anything that is encrypted.
As jon has already noted, the HP-1 is not a good choice for simulcast. While the HP-2 can receive P25 Phase II, it also is not a good choice for simulcast. Read more about Simulcast in the Wiki:
Simulcast digital distortion - The RadioReference Wiki
Simulcast issues are extremely location specific. Depending on your exact location in relation to the transmit towers, you might be able to listen with no problems, or everything may be garbled so badly you cannot understand what was being said. If you can give a better idea of your general location (like a highway or major thoroughfare intersection, or a neighborhood), one of the Tarrant County members might could tell you whether or not they have problems in your vicinity. On
FWRRS, Arlington, Grand Prairie, Irving, and the Ellis County cities are using P25 Phase II (that's designated by a
T in the mode column). Everyone else on the system, for now, is still Phase I (Mode
D). But at some point, I suspect that more, if not all, of the users will end up migrating to Phase II, so a Phase II capable scanner is what you should look for. Other than Uniden's SDS series scanners, the Unication pagers and the
Blue Tail receiver also handle simulcast, though neither of those is a true scanner, and you don't have the options for monitoring multiple system types that are available with a scanner.
