New to SDRConsole V3 with Dongle
XPS720
Windham County, Connecticut
My SDRConsole V3 must of had a changed of setting trying to explore settings. My LSB and USB are hard to listen to. No matter where I place the | | listen markers,left or right side I am not able to get a proper speech. I did try calibration reset but no good. Help me get my HF MB SSB.
Thank you.
KE5MC
Lewisville, TX
Its been a long time since using SDRConsole, but in other applications a larger than needed frequency step size could be messing with fine tuning a LSB/USB signal depending on how you are changing frequency.
KE5MC
Lewisville, TX
When you change frequency of 14.137.000 is the 7 the only number that changes. It looks like DSB is set to 100 Hz. Change SSB to same for finer control. I believe you can put your cursor over the left hand .000 zero and change it with the mouse wheel. Likely master reset directions can be found in the help file, but I don't know that for sure.
P.S. With todays transceivers frequency changes can be in steps and not smooth and continuous like old school with capacitive tuning.
